lift.carDriveStatus |
Indicates the current status of the lift's motor drive system.
Property carDriveStatus of object lift can be read and written using a single IOTag.
lift-<objectAddress>.carDriveStatus |
<type> = 59 |
<property> = 453 |
An integer representing one of the options of enumeration <BACnetLiftCarDriveStatus>.
