lift.carDoorZone |
Indicates whether (TRUE) or not (FALSE) the car is in the door zone, the region near the landing where the door is permitted to start opening.
Property carDoorZone of object lift can be read and written using a single IOTag.
lift-<objectAddress>.carDoorZone |
<type> = 59 |
<property> = 452 |
