lift.carAssignedDirection |
Represents the direction the lift is assigned to move, based on current car calls.
Property carAssignedDirection of object lift can be read and written using a single IOTag.
lift-<objectAddress>.carAssignedDirection |
<type> = 59 |
<property> = 448 |
An integer representing one of the options of enumeration <BACnetLiftCarDirection>.
