lifeSafetyZone.notificationClass |
Specifies the notification class to be used when handling and generating event notifications for this object.
Property notificationClass of object lifeSafetyZone can be read and written using a single IOTag.
lifeSafetyZone-<objectAddress>.notificationClass |
<type> = 22 |
<property> = 17 |
A 32-bit unsigned integer.
