lifeSafetyZone.eventAlgorithmInhibitRef |
Indicates the property which controls the value of property Event_Algorithm_Inhibit. When this property is present and initialized (contains an instance other than 4194303), the referenced property shall be of type BACnetBinaryPV or BOOLEAN.
Property eventAlgorithmInhibitRef of object lifeSafetyZone can be read and written using a single IOTag.
lifeSafetyZone-<objectAddress>.eventAlgorithmInhibitRef |
<type> = 22 |
<property> = 355 |
A string representing an object and a property in the syntax: '<objectType>-<objectAddress>.<property>'. An optional array index '(<index>)' can be used on array properties.
