lifeSafetyPoint.setting |
Used to convey the desired setting of the input(s) or process used to determine the logical state of the Present_Value.
Property setting of object lifeSafetyPoint can be read and written using a single IOTag.
lifeSafetyPoint-<objectAddress>.setting |
<type> = 21 |
<property> = 162 |
An 8-bit integer value ranging from 0 to 255.
