lifeSafetyPoint.profileLocation |
Property profileLocation of object lifeSafetyPoint can be read and written using a single IOTag.
lifeSafetyPoint-<objectAddress>.profileLocation |
<type> = 21 |
<property> = 485 |
A string value.
