lifeSafetyPoint.directReading |
Indicates an analog quantity that reflects the measured or calculated reading from an initiating device.
Property directReading of object lifeSafetyPoint can be read and written using a single IOTag.
lifeSafetyPoint-<objectAddress>.directReading |
<type> = 21 |
<property> = 156 |
A 32-bit floating point number.
