largeAnalogValue.resolution |
Indicates the smallest recognizable change in presentValue in engineering units (read-only).
Property resolution of object largeAnalogValue can be read and written using a single IOTag.
largeAnalogValue-<objectAddress>.resolution |
<type> = 46 |
<property> = 106 |
A 64-bit floating point number.
