largeAnalogValue.relinquishDefault |
The default value to be used for the presentValue property when all command priority values in the priorityArray property have a NULL value.
Property relinquishDefault of object largeAnalogValue can be read and written using a single IOTag.
largeAnalogValue-<objectAddress>.relinquishDefault |
<type> = 46 |
<property> = 104 |
A 64-bit floating point number.
