largeAnalogValue.lowLimit |
Specifies a limit that the presentValue must fall below before an event is generated.
Property lowLimit of object largeAnalogValue can be read and written using a single IOTag.
largeAnalogValue-<objectAddress>.lowLimit |
<type> = 46 |
<property> = 59 |
A 64-bit floating point number.
