integerValue.resolution |
Indicates the smallest recognizable change in presentValue in engineering units (read-only).
Property resolution of object integerValue can be read and written using a single IOTag.
integerValue-<objectAddress>.resolution |
<type> = 45 |
<property> = 106 |
A 32-bit signed integer.
