integerValue.relinquishDefault |
The default value to be used for the presentValue property when all command priority values in the priorityArray property have a NULL value.
Property relinquishDefault of object integerValue can be read and written using a single IOTag.
integerValue-<objectAddress>.relinquishDefault |
<type> = 45 |
<property> = 104 |
A 32-bit signed integer.
