integerValue.lowLimit |
Specifies a limit that the presentValue must fall below before an event is generated.
Property lowLimit of object integerValue can be read and written using a single IOTag.
integerValue-<objectAddress>.lowLimit |
<type> = 45 |
<property> = 59 |
A 32-bit signed integer.
