integerValue.faultLowLimit |
Specifies a limit that the Present_Value must fall below before a fault event is generated by the FAULT_OUT_OF_RANGE fault algorithm.
Property faultLowLimit of object integerValue can be read and written using a single IOTag.
integerValue-<objectAddress>.faultLowLimit |
<type> = 45 |
<property> = 389 |
A 32-bit signed integer.
