integerValue.faultHighLimit |
Specifies a limit that the Present_Value must exceed before a fault event is generated by the FAULT_OUT_OF_RANGE fault algorithm.
Property faultHighLimit of object integerValue can be read and written using a single IOTag.
integerValue-<objectAddress>.faultHighLimit |
<type> = 45 |
<property> = 388 |
A 32-bit signed integer.
