globalGroup.updateInterval |
Indicates the maximum period of time between updates to the presentValue in hundredths of a second when the input is not overriden and not out-of-service.
Property updateInterval of object globalGroup can be read and written using a single IOTag.
globalGroup-<objectAddress>.updateInterval |
<type> = 26 |
<property> = 118 |
A 32-bit unsigned integer.
