globalGroup.requestedUpdateInterval |
Indicates the requested period of time between updates to Present_Value, measured in hundredths of a second when the object is not out-of-service.
Property requestedUpdateInterval of object globalGroup can be read and written using a single IOTag.
globalGroup-<objectAddress>.requestedUpdateInterval |
<type> = 26 |
<property> = 348 |
A 32-bit unsigned integer.
