globalGroup.groupMembers |
Defines the members of the group. If the optional device identifier is not present for a particular group member, then that object shall reside in the same device that maintains the Global Group object.
Property groupMembers of object globalGroup can be read and written using a single IOTag.
globalGroup-<objectAddress>.groupMembers |
<type> = 26 |
<property> = 345 |
A character string containing an XML with a value of type <SequenceOfBACnetDeviceObjectPropertyReference>.
