globalGroup.covuPeriod |
Indicates the amount of time in seconds between the periodic unsubscribed COV notifications performed by this object. These COV notifications convey the value of the Present_Value and Member_Status_Flags properties. If the value of COVU_Period is zero, then periodic unsubscribed COV notification messages shall not be transmitted.
Property covuPeriod of object globalGroup can be read and written using a single IOTag.
globalGroup-<objectAddress>.covuPeriod |
<type> = 26 |
<property> = 349 |
A 32-bit unsigned integer.
