globalGroup.covResubscriptionInterval |
Specifies the number of seconds between COV resubscriptions, provided that COV subscription is in effect.
Property covResubscriptionInterval of object globalGroup can be read and written using a single IOTag.
globalGroup-<objectAddress>.covResubscriptionInterval |
<type> = 26 |
<property> = 128 |
A 32-bit unsigned integer.
