globalGroup.clientCovIncrement
Specifies the increment to be used in determining that a change of value has occurred.
Property clientCovIncrement of object globalGroup can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
globalGroup-<objectAddress>.clientCovIncrement
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 26
N3:
<objectAddress>
N4:
<property> = 127
Tag Value
•A 32-bit floating point number.
•A null/empty value.
