eventLog.notificationThreshold |
Contains the pThreshold parameter for the object's event algorithm.
Property notificationThreshold of object eventLog can be read and written using a single IOTag.
eventLog-<objectAddress>.notificationThreshold |
<type> = 25 |
<property> = 137 |
A 32-bit unsigned integer.
