eventEnrollment.faultType |
Indicates the type of fault algorithm that is applied by the object.
Property faultType of object eventEnrollment can be read and written using a single IOTag.
eventEnrollment-<objectAddress>.faultType |
<type> = 9 |
<property> = 359 |
An integer representing one of the options of enumeration <BACnetFaultType>.
