eventEnrollment.eventType |
Indicates the type of event algorithm that is to be used to detect the occurrence of events and report to enrolled devices. 0 = change of bit string, 1 = change of state, 2 = change of value, 3 = command failure, 4 = floating limit, 5 = out of range
Property eventType of object eventEnrollment can be read and written using a single IOTag.
eventEnrollment-<objectAddress>.eventType |
<type> = 9 |
<property> = 37 |
An integer representing one of the options of enumeration <BACnetEventType>.
