escalator.powerMode |
Indicates whether (TRUE) or not (FALSE) the escalator is powered (independent of whether it is moving).
Property powerMode of object escalator can be read and written using a single IOTag.
escalator-<objectAddress>.powerMode |
<type> = 58 |
<property> = 479 |
