escalator.energyMeter |
Indicates the accumulated energy consumption by the lift. The units shall be kilowatt-hours. When this value reaches 99999 kWh, it shall wrap to a value near zero; the particular value to which it wraps is a local matter. If the Energy_Meter_Ref property is present and initialized (contains an instance other than 4194303), then the Energy_Meter property, if present, shall contain a value of 0.0.
Property energyMeter of object escalator can be read and written using a single IOTag.
escalator-<objectAddress>.energyMeter |
<type> = 58 |
<property> = 460 |
A 32-bit floating point number.
