BACnetObjectType
BACnetObjectType
This enumeration is used by the following objects/properties:
•accessCredential.objectType
•accessDoor.objectType
•accessPoint.objectType
•accessRights.objectType
•accessUser.objectType
•accessZone.objectType
•accumulator.objectType
•alertEnrollment.objectType
•analogInput.objectType
•analogOutput.objectType
•analogValue.objectType
•averaging.objectType
•binaryInput.objectType
•binaryLightingOutput.objectType
•binaryOutput.objectType
•binaryValue.objectType
•bitstringValue.objectType
•calendar.objectType
•channel.objectType
•characterstringValue.objectType
•command.objectType
•credentialDataInput.objectType
•dateValue.objectType
•datepatternValue.objectType
•datetimeValue.objectType
•datetimepatternValue.objectType
•device.objectType
•elevatorGroup.objectType
•escalator.objectType
•eventEnrollment.objectType
•eventLog.objectType
•file.objectType
•globalGroup.objectType
•group.objectType
•integerValue.objectType
•largeAnalogValue.objectType
•lifeSafetyPoint.objectType
•lifeSafetyZone.objectType
•lift.objectType
•lightingOutput.objectType
•loadControl.objectType
•loop.objectType
•multiStateInput.objectType
•multiStateOutput.objectType
•multiStateValue.objectType
•networkPort.objectType
•networkSecurity.objectType
•notificationClass.objectType
•notificationForwarder.objectType
•octetstringValue.objectType
•positiveIntegerValue.objectType
•program.objectType
•pulseConverter.objectType
•schedule.objectType
•structuredView.objectType
•timeValue.objectType
•timepatternValue.objectType
•timer.objectType
•trendLog.objectType
•trendLogMultiple.objectType
The enumeration values are:
Value
Name
0
analogInput
1
analogOutput
2
analogValue
3
binaryInput
4
binaryOutput
5
binaryValue
6
calendar
7
command
8
device
9
eventEnrollment
10
file
11
group
12
loop
13
multiStateInput
14
multiStateOutput
15
notificationClass
16
program
17
schedule
18
averaging
19
multiStateValue
20
trendLog
21
lifeSafetyPoint
22
lifeSafetyZone
23
accumulator
24
pulseConverter
25
eventLog
26
globalGroup
27
trendLogMultiple
28
loadControl
29
structuredView
30
accessDoor
31
timer
32
accessCredential
33
accessPoint
34
accessRights
35
accessUser
36
accessZone
37
credentialDataInput
38
networkSecurity
39
bitstringValue
40
41
datepatternValue
42
dateValue
43
44
datetimeValue
45
integerValue
46
largeAnalogValue
47
octetstringValue
48
49
timepatternValue
50
timeValue
51
52
alertEnrollment
53
channel
54
lightingOutput
55
56
networkPort
57
elevatorGroup
58
escalator
59
lift
