elevatorGroup.machineRoomId |
References the Positive Integer Value Object whose Present_Value property contains the identification number for the machine room that contains the group of lifts or escalators represented by this object. If there is no such identification number, this property shall contain an object instance number of 4194303.
Property machineRoomId of object elevatorGroup can be read and written using a single IOTag.
elevatorGroup-<objectAddress>.machineRoomId |
<type> = 57 |
<property> = 474 |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345').
