device.vendorIdentifier |
A unique vendor identification code, assigned by ASHRAE, which is used to distinguish proprietary extensions of the protocol.
Property vendorIdentifier of object device can be read and written using a single IOTag.
device-<objectAddress>.vendorIdentifier |
<type> = 8 |
<property> = 120 |
A 16-bit integer value ranging from 0 to 65535.
