device.utcOffset |
Indicates the number of minutes (-720 to +720) offset between local standard time and Universal Time Coordinated. The time zones to the west of the zero degree meridian shall be positive values, and those to the east shall be negative values.
Property utcOffset of object device can be read and written using a single IOTag.
device-<objectAddress>.utcOffset |
<type> = 8 |
<property> = 119 |
A 32-bit signed integer.
