device.timeSynchronizationInterval |
Specifies the periodic interval in minutes at which TimeSynchronization and UTCTimeSynchronization requests shall be sent.
Property timeSynchronizationInterval of object device can be read and written using a single IOTag.
device-<objectAddress>.timeSynchronizationInterval |
<type> = 8 |
<property> = 204 |
A 32-bit unsigned integer.
