device.timeOfDeviceRestart
Contains the time at which the device was last restarted.
Property timeOfDeviceRestart of object device can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
device-<objectAddress>.timeOfDeviceRestart
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 8
N3:
<objectAddress>
N4:
<property> = 203
Tag Value
A Date, Integer, Null or String (Xml) value representing a timestamp in BACnet.
•A null value means the timestamp is empty/not set;
•A date/time value representing a precise date and time;
•An integer defining the timestamp sequence number;
•A character string containing an XML with a value of type <BACnetTimeStamp>.
