device.segmentationSupported |
Indicates whether the BACnet Device supports segmentation of messages, and, if so, whether it supports segmented transmission, reception, or both. 0 = both, 1 = transmit, 2 = receive, 3 = no segmentation
Property segmentationSupported of object device can be read and written using a single IOTag.
device-<objectAddress>.segmentationSupported |
<type> = 8 |
<property> = 107 |
An integer representing one of the options of enumeration <BACnetSegmentation>.
