device.restorePreparationTime |
Indicates the amount of time in seconds that the device is allowed to remain unresponsive after the sending of a ReinitializeDevice-ACK at the start of a restore procedure. The restoring device shall either wait or be prepared to encounter communication timeouts during this period.
Property restorePreparationTime of object device can be read and written using a single IOTag.
device-<objectAddress>.restorePreparationTime |
<type> = 8 |
<property> = 341 |
A 16-bit integer value ranging from 0 to 65535.
