device.protocolServicesSupported |
Indicates which standardized protocol services are supported by this device's protocol implementation.
Property protocolServicesSupported of object device can be read and written using a block tag with 44 elements.
device-<objectAddress>.protocolServicesSupported |
Size |
44 elements |
B1: |
B2: |
<type> = 8 |
B3: |
B4: |
<property> = 97 |
44 elements |
Index |
Name |
Type |
0 |
acknowledgeAlarm |
1 |
confirmedCovNotification |
2 |
confirmedEventNotification |
3 |
getAlarmSummary |
4 |
getEnrollmentSummary |
5 |
subscribeCov |
6 |
atomicReadFile |
7 |
atomicWriteFile |
8 |
addListElement |
9 |
removeListElement |
10 |
createObject |
11 |
deleteObject |
12 |
readProperty |
13 |
_unmappedBit13 |
This element is unused. |
14 |
readPropertyMultiple |
15 |
writeProperty |
16 |
writePropertyMultiple |
17 |
deviceCommunicationControl |
18 |
confirmedPrivateTransfer |
19 |
confirmedTextMessage |
20 |
reinitializeDevice |
21 |
vtOpen |
22 |
vtClose |
23 |
vtData |
24 |
_unmappedBit24 |
25 |
_unmappedBit25 |
26 |
iAm |
27 |
iHave |
28 |
unconfirmedCovNotification |
29 |
unconfirmedEventNotification |
30 |
unconfirmedPrivateTransfer |
31 |
unconfirmedTextMessage |
32 |
timeSynchronization |
33 |
whoHas |
34 |
whoIs |
35 |
readRange |
36 |
utcTimeSynchronization |
37 |
lifeSafetyOperation |
38 |
subscribeCovProperty |
39 |
getEventInformation |
40 |
writeGroup |
41 |
subscribeCovPropertyMultiple |
42 |
confirmedCovNotificationMultiple |
43 |
unconfirmedCovNotificationMultiple |
