device.protocolRevision |
Indicates the minor revision level of the BACnet standard.
Property protocolRevision of object device can be read and written using a single IOTag.
device-<objectAddress>.protocolRevision |
<type> = 8 |
<property> = 139 |
A 32-bit unsigned integer.
