device.protocolObjectTypesSupported |
Indicates which standardized object types are supported by this device's protocol implementation.
Property protocolObjectTypesSupported of object device can be read and written using a block tag with 60 elements.
device-<objectAddress>.protocolObjectTypesSupported |
Size |
60 elements |
B1: |
B2: |
<type> = 8 |
B3: |
B4: |
<property> = 96 |
60 elements |
Index |
Name |
Type |
0 |
analogInput |
1 |
analogOutput |
2 |
analogValue |
3 |
binaryInput |
4 |
binaryOutput |
5 |
binaryValue |
6 |
calendar |
7 |
command |
8 |
device |
9 |
eventEnrollment |
10 |
file |
11 |
group |
12 |
loop |
13 |
multiStateInput |
14 |
multiStateOutput |
15 |
notificationClass |
16 |
program |
17 |
schedule |
18 |
averaging |
19 |
multiStateValue |
20 |
trendLog |
21 |
lifeSafetyPoint |
22 |
lifeSafetyZone |
23 |
accumulator |
24 |
pulseConverter |
25 |
eventLog |
26 |
globalGroup |
27 |
trendLogMultiple |
28 |
loadControl |
29 |
structuredView |
30 |
accessDoor |
31 |
timer |
32 |
accessCredential |
33 |
accessPoint |
34 |
accessRights |
35 |
accessUser |
36 |
accessZone |
37 |
credentialDataInput |
38 |
networkSecurity |
39 |
bitstringValue |
40 |
characterstringValue |
41 |
datepatternValue |
42 |
dateValue |
43 |
datetimepatternValue |
44 |
datetimeValue |
45 |
integerValue |
46 |
largeAnalogValue |
47 |
octetstringValue |
48 |
positiveIntegerValue |
49 |
timepatternValue |
50 |
timeValue |
51 |
notificationForwarder |
52 |
alertEnrollment |
53 |
channel |
54 |
lightingOutput |
55 |
binaryLightingOutput |
56 |
networkPort |
57 |
elevatorGroup |
58 |
escalator |
59 |
lift |
