device.maxMaster |
Specifies the highest possible address for master nodes, and shall be less than or equal to 127.
Property maxMaster of object device can be read and written using a single IOTag.
device-<objectAddress>.maxMaster |
<type> = 8 |
<property> = 64 |
A 32-bit unsigned integer.
