device.maxInfoFrames |
Specifies the maximum number of information frames the node may send before it must pass the token.
Property maxInfoFrames of object device can be read and written using a single IOTag.
device-<objectAddress>.maxInfoFrames |
<type> = 8 |
<property> = 63 |
A 32-bit unsigned integer.
