device.maxApduLengthAccepted |
The maximum number of octets that may be contained in a single, indivisible application layer protocol data unit.
Property maxApduLengthAccepted of object device can be read and written using a single IOTag.
device-<objectAddress>.maxApduLengthAccepted |
<type> = 8 |
<property> = 62 |
A 32-bit unsigned integer.
