device.deployedProfileLocation |
Represents the URI of the location of an xdd file. The URI is restricted to using only the "http", "https", and "bacnet" URI schemes. The referenced xdd file contains additional information about the deployed device. It is intended to be used as a supplement to the information referenced by the Profile_Location property. If present, this property shall be writable and shall, at a minimum, support storage of strings with an encoded length up to 255 octets.
Property deployedProfileLocation of object device can be read and written using a single IOTag.
device-<objectAddress>.deployedProfileLocation |
<type> = 8 |
<property> = 484 |
A string value.
