device.alignIntervals |
Specifies whether (TRUE) or not (FALSE) clock-aligned periodic time synchronizations is enabled.
Property alignIntervals of object device can be read and written using a single IOTag.
device-<objectAddress>.alignIntervals |
<type> = 8 |
<property> = 193 |
