datetimeValue.isUtc |
Indicates whether the Present_Value property indicates a UTC date and time (when TRUE) or a local date and time (when FALSE). If this property is absent, the Present_Value shall be a local date and time.
Property isUtc of object datetimeValue can be read and written using a single IOTag.
datetimeValue-<objectAddress>.isUtc |
<type> = 44 |
<property> = 344 |
