datetimeValue.currentCommandPriority
Indicates the currently active priority. The value of this property shall be equal to the index of the entry in the Priority_Array from which the Present_Value's value has been taken. If Present_Value has taken on the value of Relinquish_Default, this property shall have the value Null.
Property currentCommandPriority of object datetimeValue can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
datetimeValue-<objectAddress>.currentCommandPriority
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 44
N3:
<objectAddress>
N4:
<property> = 431
Tag Value
•A null/empty value.
•A 32-bit unsigned integer.
