datepatternValue.relinquishDefault |
The default value to be used for the presentValue property when all command priority values in the priorityArray property have a NULL value.
Property relinquishDefault of object datepatternValue can be read and written using a single IOTag.
datepatternValue-<objectAddress>.relinquishDefault |
<type> = 41 |
<property> = 104 |
A Date/Time value (only the Date part).
