credentialDataInput.supportedFormats |
Specifies which authentication factor formats are supported by this object.
Property supportedFormats of object credentialDataInput can be read and written using a single IOTag.
credentialDataInput-<objectAddress>.supportedFormats |
<type> = 37 |
<property> = 304 |
A character string containing an XML with a value of type <SequenceOfBACnetAuthenticationFactorFormat>.
