channel.writeStatus |
Set to IDLE initially. This property shall be set to IN_PROGRESS when a value is written to the Present_Value property indicating that the Channel object has begun processing the List_Of_Object_Property_References.
Property writeStatus of object channel can be read and written using a single IOTag.
channel-<objectAddress>.writeStatus |
<type> = 53 |
<property> = 370 |
An integer representing one of the options of enumeration <BACnetWriteStatus>.
