channel.listOfObjectPropertyReferences |
Specifies the Object and Property identifiers of the properties to be written with specific values at specific times on specific days.
Property listOfObjectPropertyReferences of object channel can be read and written using a single IOTag.
channel-<objectAddress>.listOfObjectPropertyReferences |
<type> = 53 |
<property> = 54 |
A character string containing an XML with a value of type <SequenceOfBACnetDeviceObjectPropertyReference>.
