channel.lastPriority |
Conveys the priority at which the Present_Value was most recently written (1..16). If an attempt was made to write to the Present_Value without the 'Priority' parameter, a default priority of 16 (the lowest priority) shall be assumed. The initial value of Last_Priority shall be 16.
Property lastPriority of object channel can be read and written using a single IOTag.
channel-<objectAddress>.lastPriority |
<type> = 53 |
<property> = 369 |
A 32-bit unsigned integer.
